Fixing DENTS!?!?!
  • Fixing DENTS!?!?!
    She's got a few dents and dings here and there, I understand what needs to be done but what has worked for you all? Thanks, I don't know whether to invest in any sort of 'puller.'
    -JD
    Depends on where they are , You might be able to take interior panels out and push them out , if it did not crease the metal .
    The one I have above the rear tire , if I hit above the body contour , I can pop it back out .
    If it is too bad ,you are prolly talking pulling it and some bondo to patch a small hole .
    HD2500 Duramax Chevy
    Z28 LS1 power 500 +
      PLUNGER!!! No joke, get er wet and pull em out!! Worked great for me.
      *1992 Sport "Beauty" and 1989 L "Beast"
        Body filler and sandpaper is your friend. Like packrat said it all depends where they are located on the ca and how small/big they are. My passenger side Quarter panel is caved in, I'm actually going to take a dremel cutoff wheel to the junkyard the next time I go and section out a good piece.
