festiva tranny removal
  • festiva tranny removal
    is there enough room to remove the tranny without pulling the engine? I don't really want to pull this engine again, but I need to fix the tranny... Thanks
    yes not a prob.
    Clinton
      so how do i go about dropping it. center support and take it straight down or pull out towards the drivers side?
        you'll have to shift it to the drivers side to disengage the input shaft from the clutch then take it out, leave it on the cross member for simplicity
        Jesus is on my dashboard, But the Devil is under my hood
        1988 ford festiva...in limbo, apartments suck
        1995 Ford Aspire...in limbo, wow i need a garage
        2002 vw jetta wagon 2.0L, neuspeed p-flow 1994 Mercury cougar xr-7 v8, lowered, 18's
