Noise from front right wheel!?!?
  • Noise from front right wheel!?!?
    So everytime I turn all the way left it makes this like clicking/banging noise... when I did my aspire brake swap I didn't notice anything wrong... I don't know what it could be?!?!? it sounds pretty gross! I thought the swap would fix it or something might be loose. thanks all-
    Did it do this before the swap? It sounds like a CV joint is bad.
    93 GL modyfied!!!
    :fish:
      wheel bearing, control arm, tie rod end, or CV. My guess is the CV also.. Does it have a boot on there?? If not the dirt will settle in enabling it not move as much.
