Belt squeal...
  • Belt squeal...
    I've got a belt squeal in my 90L that's getting progressively worse...and as of yesterday got so bad i actually smelled burning rubber.
    How hard is this to replace? I was considering just having Penzoil do it when i get my oil changed in the next week or two....but if it's easy I'll save the $ and do it myself.
    For what it's worth i and very mechanically inclined, just wondering how involved the swap is.
    ~Josh
    99 SVT "BLKOUT2" - # 1571 - PRT track whore
    98 SVT - PRT R&D car
    90 Festiva "BLKTIVA"
    The alt/water pump belt is an easy change. Could just be loose. Could also be a bearing in the alternator failing.
      if i recalled a 14mm socket on the bottom bolt and a 10mm on the top bolt. the bottom bolt head is on the other side towards the engine and it is a long bolt but just loosen it and do not remove it.
        I have also had success using a product called 'belt grip'. I found it at work where we use it on a bunch of stuff and it's from a spray can too, so really easy to apply. (That is- after i checked the bearings, tension, and replaced the belts.)
          Do you have A/C? If so you will need to take that belt off too to change the Alt/Water pump belt. If you've smelled burning rubber, I would go ahead and replace it. I keep a spare one in my car (has saved me once already).
          I actually think the top bolt is 12MM, not 10MM.
          It's a pretty simple and quick task :thumbright:
          91 Festiva L
            you may have to retighten the belt after a few thousand miles
              i had that same problem with my 1990 and mine kept squeeling but you need to make sure it's not over tight, i overtightened mine :shock: needless to say i had to walk home . and another thing i had to use that belt dressing stuff it's like mine got real dry and after a few days of spraying that i haven't had any problems other than normal tighntening
              ***THE VWCHOPPERMAN***
              (2)90 festivas
              66 VW Bus - 66 VW Beetle
              1979 Yamaha XS 650 chopper
                My last belt started squealing , I replaced it with a Gates , it still squealed ??, I had to tighten it a little more than I felt comfortable with , to make the squeal subdue .
                HD2500 Duramax Chevy
                Z28 LS1 power 500 +
