Does any one of you guys know what is the correct procedure for breaking in a recently overhauled engine ,B3 by the way, and what oil should be used for this????
Overhaul
Everyone does it different , But I still go by the old rule of thumb . Break them in like you are going to drive it.
As for oil I run 10W30 Pennz in everything , except the Hot rod's , it gets 5 W50 Castrol Syntec .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
Run it in for the first 20 minutes at 2000rpm using regular oil. Change the oil. Drive it for a couple thousand miles (don't beat on it too much) with regular oil. Change the oil. After that, do what you do.
The first 20 minutes are critical for breaking in. The cam and lifters become good friends, and the rings start to seat. The next couple thousand miles are just to be sure everything gets together and meshes. After it's done, you can run whatever oil you want, drive it like you want, whatever.
I agree with Packrat427 except for the oil,I prefer 10W30 Castro regular car. Hot rod MOBIL 1 ,Motorcycles Mobil 1 for motorcyclesRenegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
6,500-7,000 rpm start ups break the cam, and main bearings in just right. Hold firm at 6,000 until it starts missing, and then you are ready for three consecutive 4,000 rpm clutch drops, or 7,000 rpm neutral drop if you have an automatic.--Jeremie
Quaker State 20W50 in your climate should be fineRenegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
i read on mazda protege.net or something (not sure) that the procedure should be something like this:
1) start up let idle for 20 min (or at least untill temp guage reaches full operating temp for a few min). after idle, change the oil.
2) take it out on a fairly empt peice of road and open it up to full-throttle in third, take your foot off the gass and coast down to 2-3k rpms WITHOUT taking it out of gear. do this 5+ times, this helps to seat the rings. Change oil and filter.
3) drive it like normal for the next 500-1k miles, change oil and filter again.
4) done, change oil at normal 3k mile intervals and drive it like you want.
I think thats the procedure i'm going to folow on my B6 when i finish the rebuild...~Nate
Current cars:
FOTY 2008 winner!
I would disagree with the idea to idle the new engine for 20 minutes. Idle should be avoided for prolonged periods of time with a new engine. Drive it around like normal to get to regular running temps and then start the full throttle runs to seat the rings.
Here is a link to some interesting reading on engine break in procedures.
1991 L 408,000 miles+ w/NEW B3 longblock!!
2008 Nissan Versa S HB
