okay, for a while i knew i needed to do a brake job on my car, i knew they were getting bad, well a few days ago the brake pedal started to go basically to the floor (it's not leaking fluid either) and didn't really do much no matter how hard i pushed on it, (i was thinking maybe a pad in the back came off the metal) so i figured time to do the aspire swap
well i got the rear brakes on (didn't have time for the front yet) and i still can barely stop the car, i will be changing the fronts shortly to the aspire brakes but the festiva ones in the front aren't that bad, so by rights i should be able to stop farely easy
what i'm wandering is could it possibly be the master cylinder that died on me? if so how do i check it? or could it be that distribution block (not sure of the real name for it) thing thats on the firewall?
any help would be great because i'm leary about driving it right now
