So as ive mentioned elsewhere, i went to go look at another festiva today..
When you try to start it it would fire but it wouldn't stay running... if you gave it some gas, you could keep it running for a couple seconds but then it would die again.
how hard would this be to fix? My friend thought it was a broken/dirty sensor. Visually the only thing i could see wrong is the valve cover was leaking and the block was caked with oil.
