festiva starting help!
    I use Seafoam in everything . there are other products out there , But Seafoam works for me , in the gas , and I use it by letting the engine suck it thru the vac. lines , I made a little video , it can help with de-carbonizing the top end .
    HD2500 Duramax Chevy
    Z28 LS1 power 500 +
      what vac line did you pull?
      because I want to do that....
      Proud owner of Casper
        Any one going to the intake will work.
        93 GL modyfied!!!
        :fish:
          Yes ^^
          If you look close you can see the one I pull off on the firewall .
          You will need to keep the RPM's up a little and pull the hose in and out of the can , as you are doing it , you will see , too much and you will kill it , it is OK to kill it at the end of the can , to load it up good , then let it soak before you restart it .
          Z28 LS1 power 500 +
            like i had said before in an other post i had both of my festivas dead in the driveway and both times it was corrosion on the coil tower of the distibuter cap.
