Festiva cuts out under load
I have an 1989 Festiva with a carbureted engine and manual tranny. 215,000 miles 100,000 on the rebuilt engine and 50,000 on the new tranny
3 weeks ago the car started to cut out when a load was placed on the engine or if I floored it in any gear but first.
This happened 10 mins after revving it up to power down a muddy road. I came to a stop light and it died. I restarted it and limped it home as it would die when ever I would stop or if I gave it too much gas. At home I found the #4 wire burnt up on the inside.
Since then,
I replaced all wires and plugs good spark in all cylinders:
Car idles great.
Car starts fine.
Car still cuts out while climbing small hills or when gas pedal is floored
Car will climb in speed if I find the “sweet spot” not to hard not to soft.
Car will not go in 5th gear no matter how gentle I am.
Then I replaced the fuel filter
Same problems
Then replaced the Catalytic converter
Same problems
Then took to a shop
They tested fuel 5.5lbs
Tested the timing good belt and right on
Tested vacuum don’t remember the # but they said it was good.
The told me it was a Carb problem
Then I rebuilt the Carb
Same problem
Then I took out the emergency shut off in the carb. The piece that the black wire goes to. Vacuum activated switch, a C ring holds a stopper in place well any way I took that out.
Still the same problem, cuts out when floored in 3rd gear, cuts out when going up hill in 3-5th, if in the sweet spot on level ground I can go in 4th, will not drive unless down hill in 5th.
The last thing I have checked it the tank pick up, which is clean, when the gas tank is pressured gas streams out of the petcock.
Please help I am stranded in Missoula, MT for 3 weeks I was suppose to be back in class 1000 miles from here 4 weeks ago. Any Ideas please call 2187918421 or email yogaslackers@gmail.com
Thank you for your time.
Sam Salwei
Proud owner the Peace, Love and Be-Happy Car for the last 4 years, it has provided me with 121,000 out of its 215,000 mile life so far.
Since then,
Car idles great.
Car starts fine.
Same problems
Same problems
Then took to a shop
Same problem
Sam Salwei
