89 auto box with EFI, trans is pressurizing the pan
  • 89 auto box with EFI, trans is pressurizing the pan
    I have an 89 festy with an auto. I noticed when I started driving it again I noticed when you pull the dip stick out the check the tran fluid it will squirt it out through the dip stick... Would the tran cooling lines being on wrong have to do with it? Or is it a problem with the seal on the front pump being blown out on the high pressure side and pressurizing the case? And where is uncle fester... he should be able to help with this! Thanks guys!!
    is the vent plugged for the trans? not so sure it would build that much pressure if it was but ........i know it'll kill most seals...2cents
    you want to blend in?, drive a honda
    92l festy car, original owner.
    2008 xls mitsubishi outlander
    1987 nissan diesel truck
