Vacuum Gauge Engine Performance Testing
A vacuum gauge shows the difference between outside atmospheric pressure and the amount of vacuum present in the intake manifold. The pistons in the engine serve as suction pumps and the amount of vacuum they create is affected by the related actions of:
# Piston rings
# Valves
# Ignition system
# Fuel control system
# Other parts affecting the combustion process (emission devices, etc.).
Each has a characteristic effect on vacuum and you judge their performance by watching variations from normal. It is important to judge engine performance by the general location and action of the needle on a vacuum gauge, rather than just by a vacuum reading. Gauge readings that may be found are as follows:
Normal Engine Operation
At idling speed, an engine at sea level should show a steady vacuum reading between 14" and 22" HG. A quick opening and closing of the throttle should cause vacuum to drop below 5" then rebound to 23" or more.
General Ignition Troubles Or Sticking Valves
With the engine idling, continued fluctuation of 1 to 2 inches may indicate an ignition problem. Check the spark plugs, spark plug gap, primary ignition circuit, high tension cables, distributor cap or ignition coil. Fluctuations of 3 to 4 inches may be sticking valves.
Vacuum readings at idle much lower than normal can indicate leakage through intake manifold gaskets, manifold-to-carburetor gaskets, vacuum brakes or the vacuum modulator. Low readings could also be very late valve timing or worn piston rings.
Exhaust Back Pressure
Starting with the engine at idle, slowly increase engine speed to 3,000 RPM, engine vacuum should be equal to or higher than idle vacuum at 3,000 RPM. If vacuum decreases at higher engine RPM's, an excessive exhaust back pressure is probably present.
Cylinder Head Gasket Leakage
With the engine Idling, the vacuum gauge pointer will drop sharply, every time the leak occurs. The drop will be from the steady reading shown by the pointer to a reading of 10" to 12" Hg or less.
If the leak Is between two cylinders, the drop will be much greater. You can determine the location of the leak by compression tests. Fuel Control System Troubles
All other systems in an engine must be functioning properly before you check the fuel control system as a cause for poor engine performance. If the pointer has a slow floating motion of 4 to 5 inches - you should check the fuel control.
# Piston rings
# Valves
# Ignition system
