Running lights
  • Running lights
    Urg, the rear running lights dont work on the passenger side. I replaced both bulbs but no luck. The brake light dose work tho. i used a circuit tester and there is no power to ither bulb back at the big connector. Where should i look first?
    89SX funtop! Fully loaded!
    RIP 90LX
    grounded out wire somewhere, i would say check the fuses but the brakes are working so ????? Maybe splice in a new connector to the bulb.
      trace the wire as far as u can back to the source, even if there is a single cut or mark in the wire, and it is anywhere near to the body or any metal at all. this would cause problems.
      Electricity is all electrons, and electrons will always try to move to a better conductor, especially a larger conductor.
      1.3Liter 4 cylinder FI , OHC, FWD, 3DR, 4ST, Stud. Tires
        well i found it
        the wire was cut by the drivers seat
        fixed it up good
        RIP 90LX
          Nice repair job there , looks good !!
          HD2500 Duramax Chevy
          Z28 LS1 power 500 +
