Just got a pair of euro tail lights. The left one has an in-line 3 amp fuse but, the right one doesn't. Should the right one have the in-line fuse? Also, one of the tail lights is missing a mounting screw. Can these screws be removed and replaced easily or are they glued in somehow? The gaskets are cracked and dried out on the outer edges but not all the way through. Will they leak? Should I replace the gaskets? I see that mouse pads work great as replacements.
Thanks, Rich
Thanks, Rich
