urg, so my friend and i took my festy out for a cruize. i let him drive it and he stalled it. then it wouldnt restart.. it turned over real good but it wouldnt fire at all. i (tried) to test for spark even back to the coil and i got nothing. but im not sure i was doing it right. i took a coupple plugs out and they were dry too.
Just pushed my festy home after it died on me
check the fuel cut off? if not that then check the fusible links under the hood by the batt.2007 Ford Taurus 23-25MPG
1976 Chevy Silverado (my toy)
1951 Ford Deluxe, being rebuilt
Have an old car truck or tractor? Go here.
http://www.aintperfect.com/
There are 3 fuses on the drivers side shock tower. They look like small pieces of wire, not fuses as you would expect. One supplies power to the ignition. Start there.
be best to replace them just to be safe, im not sure ive never dealt with this personally, but it seems a common issue on festys.2007 Ford Taurus 23-25MPG
you can get replacements that look sorta like big fuses... heres a pic
they will plug in where the wire came out of. usually if those links blow they are melted or something, if you pull them out you should be able to tell.
sometimes the block they plug into goes bad, in which case you can replace the whole block with a type that holds normal fuses.~Nate
Current cars:
FOTY 2008 winner!
Re: Just pushed my festy home after it died on me
dont be too pissed atleast it was a festi and not a hummerOriginally posted by stefanurg, so my friend and i took my festy out for a cruize. i let him drive it and he stalled it. then it wouldnt restart.. it turned over real good but it wouldnt fire at all. i (tried) to test for spark even back to the coil and i got nothing. but im not sure i was doing it right. i took a coupple plugs out and they were dry too.
ops:
There is no replacement for displacement, except for the turbo in my basement.
