How unlikely is it, that a fuel pump would give out during idle? i'm pretty sure its dirt in the gas tank because it happened when it got low. and will still turn over and get a couple quick fires off, enough to make the starter scream if u hold the ignition in. I've had the car actually turn on a few times and pumped the gas so it revved up real high , but i can't keep it going.
I'm sure its the fuel filter, but if not i can't afford to be replacing parts i dont need, especially if it is the pump.
