if you are of the thinking that adding additives to oil from any company while under reg use......is going to help,.... then you know something that all the major auto companies don't, and the oil comp. Reg oil changes are the only thing recomend to prevent crap from building in the motor.
the brk cleen is to remove all the varnish, sledge and crap in top end, while appart, to clean everthing........and is very effective.
you want to blend in?, drive a honda
92l festy car, original owner.
2008 xls mitsubishi outlander
1987 nissan diesel truck
Actually, motor oil companies know about esters. They use them all the time in all kinds of oil.
However, auto-rx has patented esters. Frank has been approached by several companies that wanted to buy it. He was afraid they'd jack the price up up or even worse, not bring it to market.
Now the rest of the additives out there.....completely useless and mostly harmful. But auto-rx works.
Teir are cars, that run on water, but G.M, or any other manf. is not going to build them, many companies make claims, I have heard most of their speeches, tryed different stuff, even had one comp. give me their product, for trial,.......none of the claims have been legit to date for ME. Oil companies spend billions on reserch and development for sure, but if the little guy's product was legit on their reserch don't you think they would just bye them out and put it into their oil and make fantastic new claims? the answer is yes.....the little guy wants to get rich just like everyone elese. I find your claims to be doubtful, if a major player in that game wanted,hey would build something so close to the original, you could never tell them apart, and by-pass the original at the patent office.
As to cleaning an engine....their are a million ways to skin that cat........befor all the chemicals, and goops,.......to clean internals, in the shops we used water.....rev er up and water bottol the carb been done lots, as an eg,........ter one apart after that.....not even junk on the comb.chambers!, or a little A.T.F in the oil, cleans all the garbage out!
every one has their opinion on goops and additives, after 270'000 on my festy, 400'000 on my nissan diesel, the only additive they had was clean oil, and both are still running strong with only 1 major on the festy, netheir has had any iron changes to date.
I have seen H.D. diesel motors run on sunflower oil in the crank, burn used veg in the fuel lines, hydrogen claims of efficiency, better fuel milage with epa claims, stop this leaks, bla, bla, bla in the 15 years of being a mech, and to date..........NONE have made mainstream, and i don't belive they will.......why?.........
regular oil maintanance clears up 90% of the problems out their.
as to the original post.........no seafoam, if the motor is coming apart, to clean the internals.....to get the varnish off and wash everything ...I....would brakecleen the @#$^ outta it!
if it is not coming apart............pull the plug outta the oil pan and blast er!
you have a second opinion on the other stuff...........
Like I said, some have offered before.
I don't think Frank is hurting for money anymore. His main market is printing presses being cleaned with this stuff. Also, it's hard to "bypass" the original at a patent. That's the thing about chemistry. Either something IS something, or it's something else. It's not like they add an extra gear and another widget and call it a new product.
Seafoam can be used in this manner. Seafoam works through two principles. Thermal shock and solvency. Water would work through thermal shock.
I run into this A LOT when talking about synthetic. The only thing I can say is that'd still be running with or without, but with it they'd be running better. Engines that last that long are the result of a good design and good manufacturing.
LOTS of products never make it to the mainstream. Either from fear, lack of advertising money, or just people think it's snake oil. Being skeptical is typically a good thing though. One of my favorite products that never made it mainstream are those walkfit insoles you see once in a while during an infomerical. My feet have never felt better!
That will improve the cosmetic appearance of the valve train. But it's not going to clean and help condition the seals. It won't improve compression and it runs a high risk of clogging the oil pickup or an oil passage. Solvents DO NOT belong in the crankcase.
Search google and you'll find plenty of people talking about auto-rx and how well it works.
I have personally purchased 15 bottles of auto-rx. I've used it in about 8 vehicles all with spectacular results. My aspire, my truck, my vic, a 78 monte carlo, 94 Toyota Pickup 22RE, Ford Taurus, Grand Prix, and an intrepid. All of them except my truck got a boost in gas mileage. It stopped a front seal leak on the monte (everything else still leaks though. LOL!) and the Taurus.
I was skeptical at first too, but after I used it once I knew it was a product that does what it claims it does. If it doesn't, Frank gives you your money back.
most offer money back ........bla, bla......you must be right, mone of the big hitters could scratch a cheque large enough to make him go away.....unlikely. :wink:
I think last time i cheked, the big boys make the most on parts.....not selling new units, if this product was substantual enough they would at least have it on the shelf. :shock: ........never been to a dealer and seen it....or been recomended it by them.
i think my maintanance is the key to long life ,.....a good wrench is hard to find, one with an open mind even harder. :lol:
this debate could go on for ever, ....the bottom line for me is if you feel better about using it go ahead...........I'll maintain my stuff like a good boy and never have a trouble..........knock on wood :lol:
