valve cover bolts
  • valve cover bolts
    hey i know this is in another topic but i figured id post here to where it will help someone else if needed.
    What is the thread pitch, and length of the valve cover bolts, i snapped one and am just gonna replace them when i get a new gasket. shocking tho its not leaking lol.
    im not lookin to buy used, tho it would prolly work i want to use grade 4-6 bolts so its not gonna snap easy.
    thanks
    2007 Ford Taurus 23-25MPG
    1976 Chevy Silverado (my toy)
    http://www.aintperfect.com/
    I'd say 6mm x 1.00
      Originally posted by mattswabb
      I'd say 6mm x 1.00
      yep you were right, i was able to take one out w/o bustin it lol. m6 1.00 and an inch long,
      ace only had 2 so i grabbed them and the vc gasket will be here tomm WOOT lol.
        also do i add gasket sealer like rtv to the vc gasket? or no since its a rubber gasket
          the manual shows to use sealant between the gasket and the valve cover in the groove. When I did the last one on my daily driver I didn't, maybe thats where my leak is coming from.
            lol the manual is in the car and was just wondering ill look for sure before i go to get it cause ill need to pick some more up, that stuff is handy for more things than you think lol
              just make sure that you don't push the rubber out tighting it up, silicone will sometimes make it move around and also cause a leak
              you want to blend in?, drive a honda
              92l festy car, original owner.
              2008 xls mitsubishi outlander
              1987 nissan diesel truck
                ok had to go get a tap and the cars hot now lol, going to get lunch and be back, luckly i dont have to drill the bolt, it rattled loose so thats good. when i get back and when its cooled off ima take the greased lighting to it and take before and after pics so ill post when done
                  ok heres pics before i cleaned it all
                    heres after cleaning (sorry only 4 photos per post as far as i know lol
