Automatic Transmission Fluid Question.
  • Automatic Transmission Fluid Question.
    I am going to change the transmission fluid on my 93 GL Sport. It has the 3 spd automatic. How many liters/quarts does it take? What is the best fluid I can buy for it? Also, what make of gasket and filter should I get?
    Thanks.
    1993 GL Sport
    A synthetic ATF (Mobil1, AMSOIL, etc) would be best.
    Otherwise ATFs are pretty close to each other.
    Wix makes very nice filters if you can find them.
    You'll need between 3 and 6 quarts of fluid depending on how much you manage to get drained out.
    www.dantheoilman.com
    Go ahead and ask me why
      Both CarQuest and Napa's filters are mad by Wix. A friend of mine tried the B&M trick shift atf fluid in his auto. Even when it was hot it still shifted firm and it's about the same price as synthetic.
        thanks.. I went to an autoparts store yeasterday and they advised that I dont run a synthetic so I just bought some Mister Transmission stuff it was about 15 bucks for 4L. I also went to Canadian Tire and picked up a gasket and filter set for 15 bucks.
        1993 GL Sport
          B&M Trick Shift is NOT what you want.
          B&M Trick Shift is Type F transmission fluid. Nothing special about it except a large price tag to make you think you're getting something special.
          Type F ATF has no friction modifiers. This are important for torque converters that are designed to have a fluid with FM. If you're racing and you can afford a new TC once in a while....get Type F fluid for quicker and harder shifts.
          If it's a street car, get Mercon.
