I am still little confusing with two festiva engine compare compression testing...
^^ It was point 210 PSI and slow leaking out the fitting.
1989 EFI Ford Festiva L-Plus. Cyl --- #1,#2,#3, and #4 are same 210 PSI peak
1993 EFI Ford Festiva GL Cyl --- #1-170, #2-165, #3-165, and #4-170 PSI peak
The 1989 L-Plus Festiva have little high compression rate above of average for stock B3 engine?
