Greetings from down-under...
I'm searching for the Side/Park Light Relay on my 1992 Ford Festiva. This is due to having main and dipped headlights but no rear/side and plate lights - I do have 12V across the fuse which shows that the stalk-switch is okay.
Where is the relay and how do you bypass the relay to check its operation?
Cheers
DJ - Wellington, NZ
Cheers
DJ - Wellington, NZ
