History:
1991 Ford Festiva L, manual trans, 5 forward gears, 1 reverse.
Bought car from friend who had the car for six years. When this problem first surfaced, he replaced the fuel filter with a cheap one and when that did not help replaced the fuel pump. That did not solve it either. He bought a truck and let the car sit for a few weeks. I bought the car from him and had to push it to get started because the battery had gone bad. Had to get a jump start at work the next day and found out the battery was bad. Replaced battery and problem almost disappeared. In fact I went for several months without a single problem, but in the last few weeks, it has surfaced again. Here are some symptoms:
When I first start the car everything sounds normal. After a few miles if I stop, I can hear the fuel pump lightly humming. After a few miles more the car starts acting like it is missing and if I pull over, I can hear the fuel pump surging loudly as in UUMMMMuuuuummmmUUUUUmmmmmUUUUmmm.
Anytime, whether driving or standing still, if I turn the ignition key off for just a second or two, it will drive fine for four to 7 miles, then it will happen again. Turning the key off and back on always corrects the problem temporarily.
Seems to be worse as the gas tank gets lower. Keeping the tank full above ¾ seems to help.
I also noticed that if I am sitting still and the fuel pump is surging, if I turn on the head lights, the pump slows down (you can hear it) but keeps surging, and in some cases the car might stall.
I have driven the car as far as 50 miles turning the key off and on every 4 to 7 miles without any other problems.
The further I drive it, the more frequent the problem. After 15 or so miles, I have to do the ignition every 1 to 2 miles.
I have lived with this problem for 6 months while driving the car to and from work daily. Recently I took the car to a Ford dealer who had a mechanic who had worked on Festivas. After 2 ½ hours the only thing he could come up with was that the “meter flow vane” (sp?) tested bad and that probably was causing the problem. He told me that Festiva parts were obsolete and he could no longer get them. I naturally turned to the internet and first found Festiva.com. Now I have some hope!!
I called Carpartswholesale.com who has a long list of Festiva parts listed on their website, but they said they did not have that part. Due to the heavy accents of the people I talked to, I assume I was speaking to someone in the Far East and perhaps they had no idea what I was talking about.
I really love my little Festiva (Poor man’s mini-cooper) and except for this problem it runs fantastically great.
Anybody have any other diagnostic ideas and/or know where I might look to get a “meter flow vane”?
Thanks for helping a new member.
Art
Art
