88 Festiva LX 5 spd manual with 130k miles.
Couple months ago the car died. Since then I've moved and gotten to working on it. The camshaft sprocket mounting bolt had snapped, so I figured I'd just replace the sprocket and all would be well. When I got all of it off I noticed some damage to the camshaft end where the sprocket mounts, as well as to the sprocket itself.
Is this a symptom of a bigger problem?
Even if it is just the sprocket, should I be concerned with the damage to the camshaft end or is that just the result of someone getting too hammer happy when putting in that dowel?
Any advice or similar situation?
