My 88 currently is having issues. One night while driving the dash dimmed and the the wipers would not work. Next mourning car wouldn't start. I figured it was just the alternator because the battery was relatively new. Then jumped it that day and it was running fine. After 15 min I turned it off and then I turned it on and it started right up. That night I started it up and the dash and headlights were dim. When I attempted to drive it stalled twice. What does this sound like to y'all? Faulty wires, bad alternator... what?
Not sure... Is it my alternator? Or something else?
Only happens with headlights on?
Next time your driving it and the headlight dims, try pulling over and shutting off the headlights and see what happens.
Might help isolate wiring issue.
Pu241'93 Blue 5spd 230K(down for clutch and overall maintanence)
check bat voltage with eng. off-should be about 12V. have someone start car while u watch the voltmeter. voltage should be about 13-15V. turn on headlights with eng. running. voltage should drop but then go up again. this would pretty much indicate a good alternator. if u don't get these readings, check alt belt for proper tension and condition before condeming the alternator.
I messed around with it today. Jumped it checked the alt tension. Everything seemed fine. Ran for 15 min turned it off and it wouldn't even click to start. I just don't understand cause the battery is only a couple months old. Is it possible its the battery?88' Ford Festiva
97' Chevy Silverado Z71
94' Chevy S-10
Is it a Walmart battery ??------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
