Inner Tie Rod Gear Bellows At Advance Auto Parts
  • Inner Tie Rod Gear Bellows At Advance Auto Parts
    I just replaced one of my inner tie rods, and while I was there I replace the bellow as well. Part# 15074 made by TRW is a great fitting replacement bellow for those of you that need one quick. I couldn't get the factory ones because none of the part stores or Ford carries them anymore, and a certain someone at FMS wouldn't awnser the phone so I picked the best one I could find in the limited inventory at Advance Auto Parts. The down side is the part will run you $19.99 a piece.--Jeremie
    Thanks Ectonine (Jeremie); excellent tip when in need of a bellows as I may need one soon. Wondered if there is any lube or grease you need to load up on and if so how much and what kind?
    E95
