Well I swapped in an efi tank into my carbed festiva because I am doing the b6t swap and decided to get the efi tank rather than keep the carbed tank. Everything bolted up nicley and I was able to get all the fuel lines to connect without to much trouble. My only problem now is that the efi wiring has a clip with 4 wires in it that connects to the fuel pump assembly and the carbed fuel pump assembly has only 2 wires that connect. My question is what wires do what on each harness and then I can go from there to wire it accordingly. Thanks in advance.
Efi fuel tank in carbed body
