Hi. Me again. My '88 sat for a week while I was out of town and it hasn't been happy since i returned. It was running fine when I parked it. When I got back, it started after pumping the gas pedal a few times, but I noticed it was sputtering and missing. Thought maybe my cap got some moisture in. Pulled it and wpied it out with a dry rag. No help. Still not convinced my fusable links were making good contact. Pulled original wires, cleaned contacts and installed new plastic fusible links. No help. Pulled air cleaner off. Found one vac line off and also noticed that my carb was loose at the base. Tightened and reassembled air cleaner. Slight help, in between misses, it runs very smoothly. If I kick it out of fast idle, it will attempt to run then "load up" and konk out if I don't feather the gas pedal. I poured a can of dry gas in tank thinking there may be water there, even though I left it with a full tank. Tomorrow, I am going to pull the plugs and check their condition. I will also check the cap again. I will also make sure I am getting good fuel flow. Need her on the road.....
Anybody have anything else I can check? Has had the following changed in the last 4 months: fule pump, fule filter (2), plugs, wires, cap/rotor, battery, fusible links, alternator belt, air filter and misc. vac hoses.
Thanks in advance.
Rick
Thanks in advance.
Rick
