I Need Someones Help Badly
  • I Need Someones Help Badly
    My 93 festiva suffered a huge electrical problem and now i have to replace the whole wiring harness for the car.... somewhere i either missed a wire or it just wasnt on the harness that i took out of another festiva.... can anyone help me????
    post your location or put it in your profile and maybe someone close by can help. other than that i don't think i've seen a complete write-up about the b3 wiring.
    92l efi 240K+ stock
      Help with what ??
      Just replacing the harness ??
      What actual problems are you having ?? I don't seen any posted .
      HD2500 Duramax Chevy
      Z28 LS1 power 500 +
        well see my radio caused a short, and then my whole wiring harness went up in smoke and now i have to replace it, but i think i have everything hooked up, but it wont crank... i dont know if i am missing a wire or not... thanks for helping me, i really appreciate it
          Is it a 5 speed or auto ??
          Did you hook up the wire for the clutch switch if it is a stick .
          Neutral safety switch for a automatic .
          Do you have power to everything , but just no crank ?
          Z28 LS1 power 500 +
            Its an auto... yeah, at least i think i have everything hooked up... my seat belts went back once, but now they wont go back up the track... and i had power to everything, but just no crank...
              C13speedy,
              For the second time!
              Your location will be of great help to us and ultimately to you!
              Please add it to your profile or in your next message.
              This especially important as wiring will likely require many hi res pics or someone to stop by and try to help you.
              Additional information such as 5spd or atx as well as any mods could be of help too.
              So correct me if I'm wrong, but you have already replaced the harness, but can't get it to fire up?
              Did you replace the fusible links and check all interior fuses, as a short could have taken them out!
              Pu241
                Check all of you grounds , sounds like a connection somewhere .
                Also check the wires going into the main box , drivers side inner fender , 3 fusible links there , One is the main power . might check this first , maybe a wire broke or came loose working on it .
                Z28 LS1 power 500 +
                  Im sorry for not including that info.... i live in Franklin West Virginia, its 93, and an automatic, and i have everything hooked up, i replaced the harness, are there any differences in harnesses between different years? i checked all the fuses and all of them appear to be good, not one of them blown, but it just wont crank...
                    Fusible link is a wire that connects in the brown box on the inner fender , drivers side , if it is loose or corroded it will not have power , do a continuity test on them if you can.
                    It has 3 of them in it .
                    Z28 LS1 power 500 +
                      ok i will try that... thank you
                        If you have any problems with the fusible link wires just upgrade them to the cartridges
                        89SX funtop! Fully loaded!
                        RIP 90LX
                          i hate to be a burden, but can someone tell me where the neutral safety switch is?
                            I don't have automatic , but it should be hooked to the linkage or the lever device on your shifter , under the cover.
                            Z28 LS1 power 500 +
                              Where do you get the cartridges to replace the fusible links?
                              1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
                              1969 Ford F100 Big Block Ranger and it was free! (coming 2/12)
