So First of all, the car has been sitting in the back yard for five years and has a blown head gasket...
1991 Festiva L (fuel injection)
So then enging is not starting. I will let you know every test I have done so far and tell you guys what has happened. so I have used starting fluid and the car fired, and stayed going just fine. The throttle worked too, it revved up. so all of the electrical timing, coil, alternator is ok right?. I disconnected the fuel filter and gas came out while turning the car over So the car has fuel just fine. Just replaced the fuel pump to have this happen.
So I am thinking of bypassing the air filter to test if it is clogged up. then check the ground wire to the fuel injection system stuff. Does anybody know where that is? And then check all of the electrical system for the fuel injection using the manual for ohms, voltage, and amps using a multimeter I will be doing that 21st, 22nd of April. Can you guys think of anything else I could do for testing whats wrong?
Joseph
Joseph
