Just had my water pump, radiator, timing belt and a tune up done on my 90 Festiva. Water pump? Yes, because it was leaking. Timing belt? While your there might as well do it also, don't know when it was done last.
Here's my question. After having all this done it seems to be getting hotter then it used to, if the temp. gauge was fuel guage it would be 3/4 full. Took it back to the mechanic, he removed the radiator cap and it didn't seem to be that hot, inotherwords the cap didn't fly off or have a lot of pressure build up in the radiator. The fan is coming on and the thermostat is opening. Everything seems to working normal, but it just gets hotter, gauge wise, then it used to. Should I worry about this or not?
Any reply would be greatly appreciated.
thanx John
thanx John
