My '93L arrived with a non functional temperature gauge.
I have replaced the sensor (note - carb'd and efi sensors don't interchange!) with one from a handy abandoned Protege, and the gauge still doesn't work.
The wire leading to the sensor is Ok, which makes me wonder if there's a problem with the cluster.
Is there any way to test to see if the gauge works? Would shorting the wire to the engine block work?
Also, in the event the wiring is bad can I run a wire directly to the cluster or does it pass through the computer on the way?
Thanks!
Tim
Thanks!
Tim
