I tried to swap the front seats from a 1989 auto into a 1990 five speed and noticed they mount differently. Just wonder if anyone else has discovered this and what they did about it. Three of the holes line up ,I guess Ill have to fab a bracket for the fourth hole. Don't know if you can swap the seat tracks out or not.
Front seat swap
Front seat swap
Celebrating 25 years of festiva(s) ownership.Tags: None
It's because of the brackets for the manual/auto seatbelts. They were different.
Seat tracks are tack welded on, if you're handy with a welder you can mount any seat you want on them.
I put a '92 GL seat in my '89L and just left the 4th bracket hanging.White '89L auto - Sold!
Silver '06 Rav4, 95k!
My car is a 1990 and had auto belt seats. I have my carpet out right now and i believe the bolt holes are there for the manual belt seats. Its the back inside mount thats different, correct? Ill have to go look. I know the bolt holes are there for the manual belts, i already got those in.89SX funtop! Fully loaded!
RIP 90LX
Originally posted by stefanIts the back inside mount thats different, correct?
I'm afraid if I don't fab a bracket the seat will sag in the back corner and tweak the track so that the seats wont adjust.sigpic
I got the older to newer or the newer to older seat swap figured out. If any one ever wants to know. You just need a couple of seat/seat belt bracket off of a parts car w/o the seat belt retractors.
But you have to also swap out these things.
And make one of these
Cut a little carpet.
Works greatsigpic
Originally posted by freshtiva View PostI tried to swap the front seats from a 1989 auto into a 1990 five speed and noticed they mount differently. Just wonder if anyone else has discovered this and what they did about it. Three of the holes line up ,I guess Ill have to fab a bracket for the fourth hole. Don't know if you can swap the seat tracks out or not.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by jasonpaulbauer View PostSo the list above of things you need.... is that to swap a newer seat into an older car or an older seat into a newer car?
What do I need to swap GL seats into my 89 L?sigpic
