The compressor clutch on my my 93 Festiva (Automatic) won't engage. I have read through the posts and have already tried swapping out the 3 relays that are near the battery. No luck there, I also ran a wire from the battery to the compressor and that will engage the clutch so the compressor should be good. Finally, the AC system is completely empty as I was about to switch to Freeze 12 and didn't want to mix it with R-12. Would the clutch not engage because the system is empty? If so will I be able to charge it with out the clutch engaged or should I run a wire from the battery to force it to engage while it is being charged? Any help is much appreciated. Thanks.
Matthew
Matthew
