Happy Memorial Day Everyone! My deepest gratitude goes out to all of you that have sacrificed past and present for this great nation.
OK, today has been good and bad. I purchased a sweet 89' FI Automatic Festiva w/ AC in spectacular condition for $350 off of Craigslist. That is the good. The bad is that it has a most peculiar problem. Before I begin let me preface this with the fact that I am a mechanical novice. I learn a lot each I work on my Festivas, but I am certainly no expert, so if I use the wrong terminology I apologize.
The car runs perfectly for a certain period time (15-45 minutes). Then it will completely die and not be able to restart for a while or restart for only a few seconds and then die again. Here is what I have already done. Swapped in another fuel pump I got from a junk yard. It started right up, but the same problem occurred a short time later. Next I took the wire in between the distributor and the coil and pulled the distributor side out leaving it still attached to the coil, I then had my wife turn it over while I jumped the spark to the frame out the car. I wanted to see if I was getting any spark. After many attempts and a few good shocks from the wire (Ouch!), I determined that I was getting a spark only intermittently. I checked this at least 20 times so I am sure. This makes sense also because the problem only occurs intermittently. I started by swapping in a new wire. No luck there. Then I swapped in a working coil. Again no luck. So I have traced the missing spark back to whatever is before the coil. After that the wiring gets messy so I thought I would throw this out to the community for assistance. It will turn over all day long so I don't think it is the starter. I think this should be an easy fix, but I need help. Any ideas? Where does the spark begin? Thanks.
