I have a 1991 Festiva L with a 5-speed. It cranked over fine but the fuel pump wouldn't kick on. So I pulled the battery out and checked the huge mess of electrical plugs that sit behind it. Everything looked fine. So I put the battery back in and turned the key. Now I have no power anywhere. The fusible links are fine, I triple checked them. The battery is good. The only things that turn on are the headlights. Anyone have any ideas on what could be the problem? Any help would be appreciated.
No Power
No Power
5 Festys and counting!!
1993 GL auto 126,000mi
1991 red 5-speed B6T G25 swap in progress 255,000mi
1990 white 5-speed/Aspire swap daily driver 273,000 mi.
1989 silver 4-speed parts car
1989 white auto El Festivo
1992 Chevy Silverado K1500 soon to have 383 stroker
1999 Mercury Sable
1992 Pontiac Bonneville SSEi Supercharged For SaleTags: None
Thanks. I'll give that a shot.5 Festys and counting!!
1999 Mercury Sable
Check the battery clamps. I had this problem once, I checked everything at AZ, starter,alt, battery. then finally I
checked the terminals, Turns out the + was loose where the wire clamps in and it just wasn't getting a good
connection.Nothing says "triumph of enthusiasm over physics" like a Front Wheel Drive race car.
- Dennis Grant
FarNorthRacing.com
I took a finger nail file , the thin board type , trimmed it down to fit in the brown fuse box , to clean up the contacts in mine , before I installed the fuses .
Trimming it a bit makes it easier to get down in the slot to clean both sides .
It is just a little too wide .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
I tried everything you guys suggested and still nothing. The headlights are still the only things that work. Anybody have any different ideas? Thanks5 Festys and counting!!
1999 Mercury Sable
I figured it out! Turns out it was the ignition switch. Thanks for the help anyway.5 Festys and counting!!
1999 Mercury Sable
where can you find an ignition switch? i checked all the autoparts stores around me as well as the dealer. no one stocks or can get one. i have the same issues as stated before. any ideas would help. thanks'91 'stiva L 5spd 77,000 original miles
'96 explorer 5.0 awd (for sale)
RIP '88 and '92 mark vii lsc's
The Kollition.....of the willing
"Why is there a little 10-amp red fuse behind the other fuse cartridges in that picture?"
^^ Yeah I was wondering the same thing.Last edited by TominMO; 09-21-2009, 10:55 AM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I had the same issues once, just lights, everything else dead.
it's those effin fuse links. I have the fuse link wire. you have to take all of it apart, clean it all, and replace the mainlink wire.
I couldnt find one for a festiva so I used one for chrysler I got in autozone, cut it and put matching ends on it.
The wires and connectors might look ok, but if nothing works but the lights, you still have a rotten connector somewhere around those links.
21st friggin century youd think they would dream up something better than putting fuse wire beside a lead acid battery.
