Starts to sputter but only in the Rain..?
  • Starts to sputter but only in the Rain..?
    I have a 1993 L.
    Car runs great, but as soon as it rains it starts to sputter, almost dies out when im stopped at a light, and then it wont accelerate no matter how much you stomp on it.
    What gives..?
    Any help/suggestions..?
    jonnyg in Calgary. 8)
    BigJonnyG
    Check to see if the dist. cap has any hairline cracks in it
      ^ you beat me to it.
      92l efi 240K+ stock
        thanks, Ill check that out.
        BigJonnyG
          Or possibly old/bad spark plug wires!
          If wires, it will get worst in high humidity environments!
          Might not even start if it has been sitting and it has rained.
          BTDT!
          Pu241
            Do a complete tune up, plugs, wires , cap and rotor.
            93 GL modyfied!!!
            :fish:
              ^^yep...you could spray wire dryer on it first...on the cap and plug wires....see if it helps...if so...they need replaced....but either way most likely the problem.
                Plugs wires or cap. One or more is your problem.
                  two times on both of my festivas the coil wire was corroded inside the distibuter cap.
                    Try wiping the ignition wires and distributor cap with a clean dry rag. I do it a couple of times a year. Did it a couple weeks ago just before taking the car for its biennial emissions test.
                      new wires dist. cap and rotor should solve the problem, and might as well change the plugs since you'd be that far into it anyway
