My new festiva has A/C but I believe it needs to be recharged, anyone know what chemical goes in this, or do all A/C systems use the same freon? I know there was some talk about the chemical was changed some years back not sure.
AC Recharge
If your unit wasn't changed to 134A you might want to consider it, as R12 is expensive and hard to come by.
And if you have a leak with the 134A you can pretty much replace it on your own.
Not so with R12, believe it is illegal for unlicensed persons in U.S. to "dispense" R12, per Montreal Protocol!'93 Blue 5spd 230K(down for clutch and overall maintanence)
yup, anyone who's equipted for it will take any leftover R12 for free. then have the system vacuumed for at least 30 min and then vac tested for 5 min minimum (it needs to hold whatever vacuum that was put in it for the entire 5 min, if it can't, you have a leak) then have the system charged w/ oil and then the R-134A. that's how it's done properly.
BTW, i'm licensed in case you were wondering.Trees aren't kind to me...
the problem with R-134A is that per pound circulated, it absorbs about 20% less heat than R-12. in 1994 when most or all new cars were manufactured with R-134A systems, the components used to circulate that refridgerant ( compressor, evap, condensor ) were designed to make up for that lack of efficiency usually by increasing the sizes of those components and/or flow rate of the refridgerant. unless you upgrade the components in a car that originally used R-12, you will notice a lack of cooling if you only substitute R-12 for R-134A. i have listened to many complaints about the disatisfaction of people who had or did the conversion when R-12 became too expensive or impossible to obtain. a better option would be to use one of the newer replacements that have become available lately. some of these have even more heat absorbing capacity than R-12 and do not require the replacement of oils and o-rings or a license to purchase. usually though you have to buy an adapter fitting and can valve to access an older R-12 system. locally, i have used a product called Enviro-Safe with excellent result. it even works with what R-12 might be still in the system.
How long have you been running the enviro-safe? I have heard such mixed opinions about the R-12 alternatives such as freeze 12 etc... I have heard everything from lack of cooling to compressors locking up so I was just curious how long it has been running for you.Originally posted by F3BZthe problem with R-134A is that per pound circulated, it absorbs about 20% less heat than R-12. in 1994 when most or all new cars were manufactured with R-134A systems, the components used to circulate that refridgerant ( compressor, evap, condensor ) were designed to make up for that lack of efficiency usually by increasing the sizes of those components and/or flow rate of the refridgerant. unless you upgrade the components in a car that originally used R-12, you will notice a lack of cooling if you only substitute R-12 for R-134A. i have listened to many complaints about the disatisfaction of people who had or did the conversion when R-12 became too expensive or impossible to obtain. a better option would be to use one of the newer replacements that have become available lately. some of these have even more heat absorbing capacity than R-12 and do not require the replacement of oils and o-rings or a license to purchase. usually though you have to buy an adapter fitting and can valve to access an older R-12 system. locally, i have used a product called Enviro-Safe with excellent result. it even works with what R-12 might be still in the system.
i've had retrofited r-12 systems blowing 40* air with r-134, i doubt that in a cabin the size of a festiva, anyone could notice a differance, given that the size of our evaporators are very close to the size of ones used in minivans.Trees aren't kind to me...
how did you remove the old freon and pull the system into a vacuum?Trees aren't kind to me...
Ive converted three festys to 134 and never noticed any difference in the cooling.sigpic
