the f... vibration is ...ha ha!
i found the solution to solve the 70 shakes.
you just have to move engine-tranny to the right side...
you have to elongate the holes in the body on the engine support about .25 in and loose all trans mount and sub frame then push tranny on right side and tight all bolt.
the problem is solved!!!
http://www.fordfestiva.com/multimediaandfun/gallery/yvan/yvan's_bp_turbo_swap.htm
i fount it yesterday when i repair my tranny (slush box), when i remove axles...the left one have only .5 in of clearance and the right one have .9 in. i center then power-train and all OK (transmission too...i stripped all teeth in the carrier where the main shaft enter the clutch pack...lol)
now ready to rock n roll with my new bf drag ta (205-50r14) :twisted:
