Hi all, just bought my first 89 Festiva LX, 115k miles, have a few things to fix, first is, the reverse lights come on when car is started and stay on, i looked under the car and at the botton of 5 speed transmission is a two wired sensor looking thing that i believe to be the switch, i traced the two wires to a connector in engine bay and broke the connection, but the lights still stay on, whice tells me i have a short in wiring, i have no hand book yet and dont see a fuse marked backup light, is there a fuse for them? or any other suggestions for fixing the reverse lights.
?? cant turn off reverse lights, help
Originally posted by 25HorseplayThe switch for the lights might be stuck in the "on" position, might need to replace it.
if you disconnected the switch and they still stayed on that would mean they are getting voltage after the switch... which seems weird if you look at the schematic. it would make sense if it used a ground switch system but not this way.89SX funtop! Fully loaded!
RIP 90LX
Are you sure you unplugged the back up light switch ? this isnt it
Originally posted by stefan[he said he disconnected the switch and they still stayed on so that would rule out the switch i think
if you disconnected the switch and they still stayed on that would mean they are getting voltage after the switch... which seems weird if you look at the schematic. it would make sense if it used a ground switch system but not this way.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Or the previous owner wired them to stay on all the time.
Its been a few years but few people used to do that around here.
I guess to keep tailgaters off their butt.
Donna,
Welcome to the site.~Jeff
1988 Festiva LX Silver 5speed. 219,000 miles. My new daily driver.
1988 Festiva L Plus Red 2brl 4speed. 504,477 miles and holding till I get the speed-o fixed.
2003 Mustang GT 5speed
Originally posted by freshtivaAre you sure you unplugged the back up light switch ? this isnt it
ops:
previous cars to fix up;
86 300ZX
85 RX7 GSL
88 Corolla FX
89 Festiva LX 2bbl 5 speed
The fifth gear switch. Dont ask, ....its function is unknown.
See #10 & #20sigpic
If you find out that it does something let me know, A wire has been off of mine for almost a year now. At least that's when I noticed it. Ive got a new switch but it seems like it is behind the cross member or something. I remembered thinking it wasn't worth changing ... since it doesn't do anything anyway. I think its been lefted over from festiva evolution.sigpic
that switch "locks out" the shift light function so that the ecm isn't telling you to shift to the next gear when you can't. this won't apply to most of us as the shift light most likely doesn't work anymore. it may also send a command via the ECM to change the spark profile for cruising speeds and activate the EGR valve. egr should only come on durring cruise situations, period.
BTW the reverse lights are shorted to power meaning that a wire has rubbed through or was bitten or pinched so that it's touching a switched power wire. only look for wires that are powered with the ignition switch.Trees aren't kind to me...
