Hello, this is kind of a repost of this thread:
Here's the body of that message:
Now then, six months later, I have the same problem, but it's a little better. I am now shifting into neutral at all intersections/going down large hills/or when I am anticipating a red light in the name of fuel efficiency. So it's not a big deal that it stalls in Drive, because it's always in Neutral, but I'd still like to know what's going on.
It's not the charging system, the battery it top notch.
I strongly think it's vacuum related, esp since the engine has been swapped and I don't know how competent the mechanic was. Problem is, I don't know anything about vacuum checking. I do have a Haynes on the way, so maybe it will help.
But what can I check vacuum-wise that could be causing a stall at idle?
Thanks for reading this ultra-long post.
-Nick.
So I just bought my first Festiva! 1990 automatic for $800 here in NE Ohio. 108k on the car, 70k on the engine. Looks fantastic, in 9/10 condition, great buy!
Anyhow, one of the problems I've found is this.
After the engine warms up, I cannot sit at intersections w/o dropping the trans into neutral. If I don't, the car will fluctuate from 100 rpm to 1000 rpm and will most likely stall. If I have the headlights on, it's almost guaranteed to stall.
Headlights off, in neutral, it idles perfectly.
When the engine is cold, or just starting to warm up, it idles fine no matter what.
I've replaced plugs, wires, distro cap and rotor. No change. I am thinking maybe alternator or battery problem, but the alt looks okay (visual inspection) and the previous owner just put a new battery in it.
Thoughts?
Thanks!
-Nick.
Thoughts?
Thanks!
-Nick.
-Nick.
ops: thank you !
