Has anyone here ever split open their tranny case to repair the seal between the two halves, and if so, is it a matter of simply splitting the case halves, or do you need to remove all the shifter detents as suggested in the manual?
Manual trans repair question
I'd follow the manual, tranny's are tricky little beast to deal with. If you insist on just tearing into it
get a busted one and practice on it first so atleast you have some idea whats going on when you
open it and pieces fallout all over your work area.Nothing says "triumph of enthusiasm over physics" like a Front Wheel Drive race car.
- Dennis Grant
FarNorthRacing.com
^^X2 i've changed axle seals before without tearing the tranny apart
I dont think hes talking about the half shaft seals.sigpic
Yes, you do need to follow the directions. Otherwise, the little detent balls will fall into the transmissions only to cause problems later. What I do is get zip-loc bags and label them (make a sketch where they came from) and put them in the bag. Sometimes the springs and balls are different. I can't remember for this trans.
Its always best to follow the directions when dealing with stuff like this.
The springs and balls are different. I just tore down one yesterday. Other than those, nothing else is going to fall out or anything like that. Just make sure when re-assembling that the shell is seating properly with no air gaps. If you try to torgue the shell down and it is not seated properly, you are going to have some problemsOriginally posted by roycehofYes, you do need to follow the directions. Otherwise, the little detent balls will fall into the transmissions only to cause problems later. What I do is get zip-loc bags and label them (make a sketch where they came from) and put them in the bag. Sometimes the springs and balls are different. I can't remember for this trans.
