location of fast idle screw help
  • location of fast idle screw help
    on cold startup, i depress pedel, turn key and engine races till warm up,
    at what rpm should the fast idle be set, and where might the adj screw be located on carb to adjust, checked haynes and of course no diagram......thanks :idea:
    previous cars to fix up;
    86 300ZX
    85 RX7 GSL
    88 Corolla FX
    89 Festiva LX 2bbl 5 speed
    If you are facing the engine bay, the screw is to the left-rear of the carb. Mine is kind of an off white, plastic screw. It is large enough that you don't need a screw driver, it can be turned by hand. If you have your haynes, then I guess you already know what rpms to set it to. Hope this helps.
    1988 L - 232K miles Batstiva
    1989 L - 247K miles Slick
      i thought that big white plastic thumb screw was the idle screw, figured the fast idle to be smaller.
      86 300ZX
      85 RX7 GSL
      88 Corolla FX
        Oh, sorry, should have read your question a little closer.
        Again, looking at the carb from in front of the car, to the right of the car, flat head screw, pain in the butt to get to. Not alot of room to maneuver.
