Headlight dimming
  • Headlight dimming
    I have a wierd problem with my headlights still. I fixed the interior speedo lights but I am reading 12.7 V between one wire and the ground and somewhere around 9V at the other wire. Does anyone know what this problem is?
    Soon to be BP'ed 92' white Festy from Worcester
    http://www.cardomain.com/ride/2669252/1
    you have a dirty ground... that 9 volts you see is the result of a voltage drop after the load. clean all your connections again including the grounds in the engine bay.
