Hi guys: here is my problem: like I mentioned before in another topic, i had my green little best overhauled. But the problem first started when the radiator fan was always on, that was fixed. Now the start motor when bad. so I toke him to the same shop that did the overhauled. they changed the flywheel because the gear was bad, completely rebuild the starter motor, and now the starter motor heads up when crank. They rechecked everything and still the same. They called the guy who rebuild the starter motor and he said that could be the ignition distributor. So they found one distributor and are going to change mine to see of that's the reason for the heading. Does this sounds reasonable to you????
89, B3 carb Festi. Not the original carb. it has now a 3k Aisin carb.
