Hello, I have an 89 festiva, fuel injected, auto tranny. I am having a problem with a lack of power after it warms up. When it's cold it starts right up and runs great for about a minute, then it gets a slight miss. When I drive it, it will not go over 45-50mph. I have changed plugs, wires, cap, rotor, O2 sensor, engine temp sensor, cleaned and checked battery and ground connections. The plugs look a little dark and glossy like it might be getting to much fuel. I had just purchased the car and the previous owner said he removed the cat converter and punched it out. Any ideas would be greatly appreciated.
Thank you, great forum!
Ive heard that some back pressure is needed for the engine to run properly, maybe the "punched out cat" is the culprit. Have you checked your fuel filter ? Where did you get that cool key fob in your avatar? I want one
