Weird Headlight Issue?
    jermnc77, Your switch assembly and the festiva are similar but not exactly the same. I'm hoping to come across one in the next few days. If not, I'm thinking about just wiring in a push/pull type light switch and installing it using one of the switch "blanks" along the dash and then also some type of bright/dim switch too, like one of the floor mounted models. Wiring is very simple for lighting assemblies.
    Thanks for all your help, info and pics.
    Jeff
    White '93 GL Auto
      You are welcome! I hope you can find a switch.
      www.cardomain.com/id/jermnc77
      Madness Committee Member & Contact Person
      www.festivamadness.com
      Festiva Madness
      Snoopy's
      4621 Atlantic Ave
      Raleigh, NC 27604
        I had the same problem with my '93 a few years ago. I changed the whole switch/wiper/turn signal assembly & that fixed it.
        Red '93 GL Auto & A/C
        Silver '89 L 4spd stick, A/C
