Well here it is. Sort of. I have just started it, only have about 6 hours or so so far. I should have it finished up by Monday or Tuesday, so check back here for updates. I am making the entire intake system out of 2 1/2"pipe. I had custom flanges built for the entire turbo. So I will also be building my own down pipe. 3" down pipe w/complete 3" exhaust. Of coarse I'll post pics.
crappy pic, I know, I'll get better, these were quickies. Basically this is the largest intercooler you can fit on a festiva and still keep the stock appearance. (the damn intercooler sticking out the grill or the bottom of the bumper! you know.) It is 9" high 28" long. I suppose you cold go longer, but you would have to pipe under or around the core support. This is packaged good.
Here is a pic of the FMS front bumper with that intercooler behind it. It did take some trimming to the air-dam. I plan on cutting the front air-dam bigger to allow more air. Once again crappy pic, but bare w/me. There's better to come.
Here is a little closer pic of the front mount and a basic look some of the modifications that have to be done to the bumper support. There is a lot of work to get this intercooler to fit. It is NOT a BOLT-IN deal. I'll get some detailed pics and a Small write up on this deal. But one thing to keep in mind is that the front bumper support is the only thing that holds together the frame rails, so it HAS to be rigid! You can't cut it out completely. I have welded all the seams, and boxed it in. Also intercooler pipe bends are very tight. I used 2 1/2" donuts from road race engineering.
Just another pic of the front bumper. Defiantly need a bigger air hole.
