Beautiful
  • #31
    Very cool! It'll look good once it's glassed and finished.
    Simon - pimptiva.com
    • #32
      I LOVE IT!!!!!!!!!!!!
      93 GL modyfied!!!
      :fish:
      • #33
        Here picture about low fuel sensor probe attached the float sensor:
        (First Pic left Festiva float sensor and right 626 Mazda float sensor)
        (Second Pic left 626 Mazda float sensor and right Festiva float sensor)
        The low fuel sensor It will bolt on Festiva float sensor no problem, but you can't use 626 Mazda float sensor because it's different angle with black float arm. Also you may need drill tiny hole to let one golden wire color come out the metal plate. Don't forget to bend the probe to near bottom of tank.
        • #34
          Can someone post or send me the wiring for this swap. I would like to see it as a stickey for others that want to do it,
          93 GL modyfied!!!
          :fish:
          • #35
            i still cant get over how good that looks, so cool, def a worth while install
            "If you're not first you're last!" -Ricky Bobby
            -91L "Oliver" Now B6DE swapped with an ATX Capri ECU on a MTX!!!!
            The little Festy that could...and did!
            (Gone on to a new life)
            -90 Ford Bronco II Eddie Bauer
