Thought I should share
  • Thought I should share
    I figure this little bit of information may help many a Festiva owner in the future. So here it goes.
    I decided to change axles, wheel bearings, and rotors this past week. I had an odd vibration, and wanted to clear the slate. The car had needed axles since I purchased it in January, so fresh axles, rotors, and wheel bearings were to go on. I pulled the spindles off to get the bearings pressed out and back in. Came back home, and just could NOT get the *stupid* axles out!!!
    I must have spent over an hour, prying with a screwdriver and various other tools, trying one side, then the other, getting no where. I ended up breaking three different Harbor Freight tools (That doesn't take much). I came inside and started browsing the forum. I saw how Conor got his axles out. In the thread that was suggested, I read up on how a floor jack was used to tug on it, and I came up with a solution.
    I tried the "On-The-Fly Hub Separator" technique earlier (it works wonderfully!), so I had these three chains of a foot each. I took one, and wrapped it around the axle, right where the axle nut is. I bolted the other end of the chain to a scooter handlebar and gave it a light tug. Nothing happened, so the second tug was slightly harder, and the axle just popped out!
    Now, I was in shock. I couldn't believe that it only took all of seven seconds to pull it out! Worried that it might have been a once in a lifetime axle removal, I walked over to the passenger side. Slid the chain over the axle, put the nut on, and gave it a light tug. It just popped out on the first try!!!
    that is ghetto but awsome!
    87 rx7
    92L starsky and hutchstiva bp swap, aspire swap, side pipes(tranny swap on the way)
    94 caddi deville
    99 f250 LD 4x4 12 inch lift on 38s
    i need more festies.
      that is a great idea, i've actually pulled apart the inner CV joint before
        i wonder if theres an adapter with a slide hammer you could use to pull it?
          wouldnt be too hard to weld up
          - back when I first got the car i had a different clutch put in and they said the left axle was galded in and they couldnt get it out but yet a week later when I drove the to town the axle sure came out because they didnt put the swing arm bolt back in tight
          92 GL - parts car
          97 aspire - parts car
          87 323 DX - daily driver
            x2 just dont try this if you want to reuse your axles. When I pulled my B6 at the JY Both CVs came apart on me... and I didn't use a tool... I just yanked on them.
            89SX funtop! Fully loaded!
            RIP 90LX
