Festiva GTA and SX!!
  • #46
    I would love to get my hands on a DOHC B3 and the ECU!
    • #47
      so what your saying is you want a BJ
      Mike, AKA the sasquatch
      • #48
        I've got the BJ blues!!!
        • #49
          You can create a BJ yourself.....if your stroke is the proper length, lol.
          • #50
            does the OP of this still know if the people are there at all..
            Seeing that coldbox interior gives me hope this thing can be Plasic fabricated to be an addon.
            the dashboards that come with the "dashtray" (RHD a certain , not sure about LHD) are basically a slip-in, slip-out option.
            also curious about the DOHC and the transmission.. was it just a standard e-series transmission too or were they fortunate enough to get a g-series in all its festiva glory?
            Avg Economy:
            Highway - 7.32L/100km
            City - yet to be determined.
            • #51
              i've seen videos on the internet that prove it too.
              Avg Economy:
              • #52
                i would love a RHD swap and power windows......
                "drive fast, take chances, and most importantly, pin it to win it"
                • #53
                  You may install power windows from a German Pride.
                  The hardest part is the dash wiring. You need to add a 30 amp fuse (not too difficult as there is one empty blue/black slot available), run three 14 ga. wires in between both door connectors (power, passenger up, passenger down), splice in the 14 ga wire from the fuse box (both switches need power to operate independently), add a 14 ga ground to the drivers door connector (both switches ground through drivers switch). Enjoy.
                  You really need to take the dash off to run these wires neatly. Good news, there are no factory relays.
                  Materials needed:
                  4 rolls of different colored 14 ga wire (one of them black)
                  1 fuse terminal from the junk yard
                  1 ring terminal for the ground wire
                  10 HM and MT .090" female terminals
                  • #54
                    thanks! are there any resources you could provide? im still new here...
                    and as far as RHD rack and dash where would i start for sourcing one?
                    [/FONT][/QUOTE]
