![](http://tapatalk.imageshack.com/v2/15/02/07/8850c26d260da7f4d1e7df46564d5195.jpg)
Fatsteeve - My '91 Festiva L
uploadfromtaptalk1423950526220.jpg at discount tire, they can't figure out how to get the wheels offYellow - '91 Festiva L - 5 speed
Selling my stock steel http://sanantonio.craigslist.org/pts/4894440156.html if anyone is interestedYellow - '91 Festiva L - 5 speed
Originally posted by burundon View PostAny suggestions on wheel spacers to increase the offset a bit in the rear. Getting to much contact on the spring perchAn idea can turn to dust or magic, depending on the talent that rubs against it.
195/50/15 I was too impatient to order a 45 series tire. And I love the way these look. I've added 1/4 inch spacers, and was still getting pretty solid contact. I shaved a bit off of the spring perch with a Dremel and then beat it smooth with a hammer. Tire sidewall Still making contact with the perch and a bit on the strut body. With the wheel off the ground I can "floss" a piece of paper through but once it has weight on it it makes contact again. No mo' Flossin' So I guess I'll go 1/2 inch spacer and take a hammer to the fenders. Just need to do the lug conversion or I'll be on 1 thread of the wheel stud.
Sent from my iPad using TapatalkYellow - '91 Festiva L - 5 speed
I spent some more time grinding on the rear strut and it's still making contact. I started reading more about spacers, and I'm not sure I want a 1/2 incher. So now I'm thinking of doing the hub centric ones but they are an inch and a half or more, not sure how I'd make room for the wheel on the outside without some serious fender action. Ugh. I figured out also that I had some play in the bearing. Took a look at it and everything was good, but the axle nut was loose, barely finger tight ...shouldn't it have a cotter pin ? Snugged it up a bit and no more wobble.
This is the wheel http://www.discounttiredirect.com/di...r=1&wd=15&rw=7
This is the tire http://www.discounttiredirect.com/di...0&rd=15&cs=195
